on 15-09-2023 16:46
My Samsung smart TV can't connect to my TiVo box despite they are on the same internet connection the TV is asking for a serial number for my TiVo box which I can't find
on 16-09-2023 09:05
Check the back and bottom of the TiVo for its serial number
18-09-2023 20:09 - edited 18-09-2023 20:10
@Dmc3 wrote:My Samsung smart TV can't connect to my TiVo box despite they are on the same internet connection the TV is asking for a serial number for my TiVo box which I can't find
If you are thinking you can access your recordings by any other means than HDMI on a TV, think again. The TiVO internet connection will only stream to mobile devices & tablets.
