S2EVY
Just joined
Reposition Exterior Wall Box
Going to need the exterior wall box moved, which department is best to deal with this?
  • 15.92K
  • 2.11K
  • 5K
Re: Reposition Exterior Wall Box
Hi @S2EVY
You should call  150 from a Virgin landline or mobile, or 0345 454 1111, option 2 (Faults
When calling Faults you will hear the automated response asking you to press 1 for the link to online support etc
Ignore all the options and don't press any buttons then you should be placed into a queue and an agent should pick up the phone and book the tech for you
Dave
Love, love and love, forever - Pele
Roger_Gooner
  • 8.77K
  • 560
  • 1.67K
This job will cost £25.
Hub 3.0, TP-Link Archer C8, TP-Link TL-SG108S 8-port gigabit switch, V6
My Broadband Ping - Roger's VM broadband connection
