denimknight
  • 14
Message 1 of 7
Replacement cable
Hi all,
We're rearranging our living room and I need to get a longer coax cable, is this something I can get from virgin or do I need to order up one from another source?
Alex
Tags (1)
DJ_Shadow1966
  • 7.14K
  • 1.36K
  • 2.02K
Message 2 of 7
Re: Replacement cable
Hello
You cannot modify any cabling yourself has to be done by Virginmedia and will be classed as a non fault call out at £99.
Regards Mike
denimknight
  • 14
Message 3 of 7
Thanks for the quick reply.
Are you sure about that?  I need to get an engineer to come out to replace the cable the coax cable that runs from the wall to the box?  That seems like a bit of a scam.
spgray
  • 2.39K
  • 139
  • 339
Problem sorter
Message 4 of 7
information given is correct.
a non-fault engineer visit is £99.
My Broadband Ping - spgray
Anonymous
Not applicable
Message 5 of 7
https://www.virginmedia.com/shop/the-legal-stuff/priceguides
details at the bottom "Technician Appointments (where chargeable)"
  • 8.48K
  • 675
  • 1.52K
Message 6 of 7
Using non-VM supplied cable has the potential of introducing noise into the network that would not only affect your connection, but all customers on the same street cabinet.
Anonymous
Not applicable
Message 7 of 7
It isn't just replacing the cable that needs to be considered. The power levels may require adjusting due to the cable length change.
If you don't want to pay £99 may I suggest you run an ethernet cable from the HUB to where your other equipment is currently situated.
