Hi all
I just put my Hub 3 into modem mode as I have just attached a Netgear Orbi system to it to boost WiFi.
I logged into the Hub 3, and as soon as I enabled modem mode the power light went red. I’ve read here that the power light is supposed to be magenta when in modem mode and that a red light means the Hub is overheating and should be turned off immediately.
The whole system seems to be working well, should I worry that the light is Red rather than Magenta and is it dangerous as Virgin suggests?
It seems like a weird coincidence that the light only went red the moment I went to modem mode if in fact it means the unit is overheating.
