MattHP6
Re-route cable from brown box to internal point
Good morning
We are having the elevation that the VM cable is currently attached to demolished, and as such need to re-route the cable. The brown box position should be ok to remain as is, so can the cable connection within the blue box just be unscrewed, the cable re-routed, and then re-connected again inside the brown box? Do I need to get VM to do this, as I understand they aren't currently doing this kind of work, in which case I do not know what alternative I have?
Thanks in advance for your help
MattHP6
nodrogd
  • 17.48K
  • 2.05K
  • 4.36K
Re: Re-route cable from brown box to internal point
As long as you are not making any changes to the cable itself it should be OK to just disconnect & then reconnect it.
VM BB TV Landline. Vonage 2nd line. Freeview/Freesat HD, ASDA/Tesco PAYG Mobile. Customer since 1993
