  • 6.49K
  • 1.01K
  • 1.61K
Message 11 of 12
Re: QRM, EMC, noisy electronic equipment, Ferrites etc etc
I've still got my SamKnows Linksys WRT160NL router from a few moons ago. I reckon it's around 10/11 years old now. They never asked for it back, however I don't think it's capable of much nowadays. Might use it as a doorstep to keep the patio doors open.
Care and good luck with the qrm take.
Dave
Have I helped? Click to mark as a Helpful Answer or use Kudos to say thanks
MasterofArts
  • 96
  • 6
Dialled in
Message 12 of 12
I'd convert it to a normal router dood there is a wiki on openwrt but it can deffo be done. .... Get it set up for little projects even as a Backup / guest WiFi or what about VPN, can't remember if that's possible on it mate tbh been a while.... 👍
May the force be with you,
MOA.
Local heart throb to anything technical.
Using a HUB 2ac in modem mode, Netgear R7800 Router with the DNS on cloudflare's, Netgear switch & NAS
image host
