Maddy_C
Message 1 of 5
Problems with TV Control App and IOS
My iPad updated itself two days ago. Since then I am unable to watch my recordings or live TV on said iPad. It gives the message “out of home streaming not allowed”. It is on the same WiFi as the TiVo box. It is working fine on my (Android) phone. I restarted the TiVo box, deleted and reinstalled the app. It seems to be a problem with the latest IOS update. Please can someone help? Thanks
  • 8.47K
  • 675
  • 1.51K
Message 2 of 5
Re: Problems with TV Control App and IOS
You should have got a message when you entered the app asking you to allow access to devices on your local LAN, you need to reply yes to this for it to work. One thing you could try is to delete the app and reinstall, this often cures problems.
Maddy_C
Message 3 of 5
Hi Tudor,
I did what you said and it worked. I reinstalled it and said “yes”. Thanks for your help with this. Ps I love your hexadecimal comment!
Maddy_C
Message 4 of 5
Hello again, Tudor helped me with this problem, but it has now returned. I have deleted and reinstalled it but the screen hasn’t appeared asking to connect to other devices. Settings within the app looked ok. I get the “out of home streaming” message again. Thanks.
Sambathedog2020
  • 41
  • 6
Dialled in
Message 5 of 5
what iOS are you running on iPad?
Is your internet with VM as well?
It might be a conflict with the internet provider if you are not with VM.
Hope this helps.
