  • 14
Manipleman
Poor Wi-Fi Connection
I keep getting a message on my Nexus7 which says Wi Fi connection failure for Virgim Media What do i do ?
  • 3.65K
  • 201
  • 610
chenks
Community elder
Re: Poor Wi-Fi Connection
what trouble shooting have you done so far?
do other devices have WIFI issues?
allensmith12
Just joined
I am using a Netgear router and I am facing the same issue. The internet connection gets disconnected again and again. Should I change Netgear router password?
  • 149
  • 14
IKbrunel
Up to speed
If you use the HUB 3  and have NOT set wireless channels to manual, IE: it is set to auto channel select.
Try a re- boot of the HUB 3. Turn off for 5 mins, then turn on.
It will select the channels with the least interference from surrounding signals.
  • 1.6K
  • 68
  • 117
Forum Team (Retired) Joe_F
Hello Manipleman,
I am sorry to hear you have had this issue have you given IKbrunel's suggestion a try?
Thanks Joe_F
  • 5
ANNAtank
download a wifi analyzer and see which channel are not so crowded and switch the router to that one as the default is 11 so if all you street do not change from default 11 will get very crowded
Anna
