Phat115
Message 1 of 8
Outside wall box broken
Hello, my outside wall box broken, the splitter and cable are exposed. Can anyone help how to fix this problem? Or advice on what kind of box I could buy for this or sent me the box with instructions guide I could try to fix it myself. Or appointed an engineer to come and fitted the box for me, I'm happy to pay for the installation charge. Pls reply to me ASAP thank you.
AFewScoops
  • 49
  • 7
Dialled in
Message 2 of 8
Re: Outside wall box broken
Hi Phat115
Which region do you live in?
A technician visit might be needed.
I work for Virgin Media, but all my options are my own.
REFER A FRIEND AND SHARE £100 BETWEEN YOU
**************ASK ME HOW***************
***************SEND A PM****************
If you found this information useful or please click thumbs up on Kudos icon and marking as a helpful answer.
THANK YOU ?
Phat115
Message 3 of 8
Hello thank you for your reply. I live in Birmingham, West Midlands.
AFewScoops
  • 49
  • 7
Dialled in
Message 4 of 8
I was hoping you lived in Yorkshire, I would of been able to fix it.
I'd recommend you call Virgin Faults to book an engineer. Either 150 from a landline or 0345 4541111from any other phone.
THANK YOU ?
Phat115
Message 5 of 8
Hi which option number do I have to press to get into them? As I try before and waited on the line for about 30mins and they hang up on me.
AFewScoops
  • 49
  • 7
Dialled in
Message 6 of 8
Go through the fault option, that way you will be able to report the fault.
THANK YOU ?
Phat115
Message 7 of 8
OK thank you for your help, I will try again tomorrow morning.
AFewScoops
  • 49
  • 7
Dialled in
Message 8 of 8
Not a problem.
hope you have no more issues.
THANK YOU ?
