@Mrringelova wrote:
Shouldn’t the cables be in some sort of protective sleeve?
Ideally yes they should be fed through green trunking.
Unfortunately I have seen many situations in my local area where there is no trunking.
My own cable was originally buried in green trunking but a re pull a few years ago left the trunking at surface level.
________________________________
GrahamI'm a Very Insightful Person, I'm here to share knowledge, I don't work for Virgin Media, I'm a VM customer. There are no guarantees that my advice will work. Learn more
