Cannonm
Outside Cable Damage
Hi, gardener cut outside exposed cable by accident and we have no broadband. How do we get repaired?
Will we have to cover cost?
Andrew-G
  • 10.43K
  • 1.66K
  • 4.77K
Re: Outside Cable Damage
Phone in, go through the fault finding pantomime and report as total loss of internet.  If you have to pay it'll only be £25, of more concern may be that if the technician concludes the cable needs re-pulling you could be waiting months for that, although they'll hopefully do a temporary fix in the meanwhile.
As a short term measure, see if you can create a wifi hot spot for the house with your mobile phone.  It won't be fast, it won't be convenient, but it may tide you over for a few days.
