Margaret16
New Sony XH95 Android TV . Can't get volume/sound on Virgin Tv remote ..channels work ok on remote
New Sony XH95 Android TV . Can't get volume/sound on remote to work but all other functions work channel select etc
  • 7.88K
  • 1.16K
  • 2.14K
Re: New Sony XH95 Android TV . Can't get volume/sound on Virgin Tv remote ..channels work ok on remote
Hi Margaret16,
Sorry to see you are having problems with the remote. If it's a new TV the remote may still be paired with your old TV.
Please can you try the instructions here /virgin-tv-pairing-tv-remote
Dave
Problem Solved? Click to mark as a Helpful Answer or use Kudos to say thanks for a useful post
