talk2taggs
My external brown box has no cover the parts have rusted and corroded must be the reason I have rubbish s
My external box which is an old brown NTL one and has been there for years is broken and some of the cables and a small metal tag are exposed.  I’m wondering if this is causing some if the intermittent problems we’re having with our connection which is not good when working from home.  How can I go about getting this fixed?  When I type this into the Help questions on VM the only options it comes up with refer to inside boxes.  Very frustrating.
spgray
  • 2.39K
  • 139
  • 341
Problem sorter
Re: My external brown box has no cover the parts have rusted and corroded must be the reason I have rubbi
call CS and report the issue.
My Broadband Ping - spgray
talk2taggs
Does anyone have a number for cs that works. I can never speak with anyone
thanks
Graham_A
  • 17.27K
  • 2.46K
  • 7.35K
The numbers to ring are 150 free from a VM mobile or landline, or 0345 454 1111 from any other phone (chargeable as standard UK landline phone no.).
If you have a mobile phone with internet access via WiFi or mobile data you could try the text message service.
https://community.virginmedia.com/t5/Digital-life/When-and-how-to-use-our-messaging-service/ba-p/425...
________________________________
Graham
I'm a Very Insightful Person, I'm here to share knowledge, I don't work for Virgin Media, I'm a VM customer. There are no guarantees that my advice will work. Learn more
