BORYSK
Just joined
Lost Volume on tv remote
Hello...Our old TV remote is on its last legs, so I ordered a new one from Virgin. Its arrived with new batteries, tried it all the buttons work except the "Volume button"..... Ordered another one thinking it was faulty, but unfortunately the volume on that one doesn't work too! .... Please help!... Thank you!
  • 14.08K
  • 1.88K
  • 4.33K
Re: Lost Volume on tv remote
Hi @BORYSK
When setting up the remote don't just accept the first code that seems  to work. Try a few others as some of the codes may be for older models and may not fully work.
You can alos try the following method (good job you have new batteries as it may take a while)
Using the remote press Home > Help and Settings > Help > Set up Remote.
Follow instructions there it should give you a series of codes to try.
You can also put 0999 in place of the code and press channel up until the TV turns off, then press ok.
Dave
