Shaniz
Message 1 of 5
Lloyds, Halifax and MBNA Banking aap not openning
I am unable to open Lloyds, Halifax and MBNA banking applications using through Virgin Media broadband. When i change this to any other internet i can access the same applications as normal. This is happening on Mobile as well as on the browser. Can someone suggest a solution??
Graham_A
  • 16.15K
  • 2.26K
  • 6.9K
Message 2 of 5
Re: Lloyds, Halifax and MBNA Banking aap not openning
Odd one. The three banks you mention are all part of the same group and use similar banking apps.  I have just checked and have no issues accessing the Halifax and MBNA apps via VM broadband.
What error messages are you getting?
________________________________
Graham
I'm a Very Insightful Person, I'm here to share knowledge, I don't work for Virgin Media, I'm a VM customer. There are no guarantees that my advice will work. Learn more
  • 8.14K
  • 650
  • 1.42K
Message 3 of 5
It’s possible that all three go through the same ‘gateway’ and your IP address for some reason ha been blacklisted. I suggest you check this out with the banks.
Shaniz
Message 4 of 5
I am getting the below error
Sorry we've had to sign you out Error 1007.
  • 8.14K
  • 650
  • 1.42K
Message 5 of 5
Contact the banks, they are the ones issuing the “Error 1007” message. Nobody else can tell you what it means.
