Chadwia123
Intermittent dropping connection
Is anyone able to assist in a re surfacing dropping  connection issue  ( previous same issue last year proved to be router ) can anyone a help ? My Post code is Cf34bs if any one can check area issues ?
  • 7.86K
  • 1.16K
  • 2.14K
Re: Intermittent dropping connection
Hi Chadwia123,
Have you looked at Check service status at the top of the page? You can also a run a test on your equipment from there.
If nothing is showing  you could also try the  Service Status number  0800 561 0061.  This often gives details of more local issues down to postcode level.
Dave
Problem Solved? Click to mark as a Helpful Answer or use Kudos to say thanks for a useful post
