Stoverlord
I’ve totally broke my 3.0 hub and the cable that goes into it
Not going to get into the boring story but I’ve totally broke my 3.0 hub and the cable that goes into it. I need to get a replacement but I can’t seem to find out how? Can I buy secondhand off eBay etc?
Thanks all
jb66
  • 12.17K
  • 900
  • 1.76K
Re: I’ve totally broke my 3.0 hub and the cable that goes into it
You may have broken the part that can't be repaired easily.  A common fault is breaking the part that the wire screws into, if this breaks you need a new hub
Stoverlord
I’ve 100% done this. How do I go about getting a new hub? I see there’s secondhand ones on eBay etc
jb66
  • 12.17K
  • 900
  • 1.76K
You should call virgin and tell them so they can post you a new hub. They usually onky charge for postage
Stolen hubs on ebay won't work I'm afriad
Stoverlord
That’s great. Thanks for your help. I’ve just managed to get through to them pretty quick 🙂
jb66
  • 12.17K
  • 900
  • 1.76K
Hopefully you will be up and running soon 🙂
