Paulo2800
  • 21
Message 1 of 11
Hub4
Hi guys and gals anyone know any info on getting the new hub 4,I live in the Wirral any plans to let us get the chance to upgrade to the new hub as I know alot of people have issues with WiFi in our homes as we all now in another lockdown,so therfore we are using broadband even more,thanks.
Anonymous
Not applicable
Message 2 of 11
Re: Hub4
You really don't want the HUB 4 with the current reported issues.
You are better off putting your existing HUB in modem mode and buying your own router/mesh system.
Paulo2800
  • 21
Message 3 of 11
Re: Hub4
Sorry not very tech savi at all what u mean about putting into modem mode and what u recommend to get as a router/mesh system for the wifi.
Anonymous
Not applicable
Message 4 of 11
Re: Hub4
The HUB, by default, is in router mode which means all devices, both wired and wireless, connect to it to acquire an internet connection. There is an option within the HUB settings to put it in modem mode, which means the HUB provides an internet connection ONLY, no wired or wireless connectivity for 'normal' devices (technically one wired device can have an internet connection):
You can then purchase your own router or mesh system that connects to the HUB using a wired (Ethernet) connection, and all your wired and wireless devices connect to YOUR router instead.
Something like:
https://www.amazon.co.uk/Deco-M4-Seamless-Coverage-Replacement/dp/B07NH1J543
https://www.tp-link.com/uk/home-networking/deco/deco-m4/
Paulo2800
  • 21
Message 5 of 11
Re: Hub4
Thanks for that
RedGooner
  • 1.93K
  • 69
  • 259
Super solver
Message 6 of 11
Re: Hub4
I have my new SH4 in modem mode with an ASUS RT-AC5300.
WOW its fast.
Red (VM SH2 AC Beta tester)
Running on 1Gbps VM service with SH4 in Modem Mode, with a ASUS RT-AC5300 router. With this setup I get Fantastic WIRED and WIRELESS Signals in my home. I dont work for VM. But I work in IT, and I know my tech.
My advice is at your own risk. If you are happy with my answers please press Kudo ?
RedGooner
  • 1.93K
  • 69
  • 259
Super solver
Message 7 of 11
Re: Hub4
Anonymous
Not applicable
Message 8 of 11
Re: Hub4
WOW its fast.
Does link aggregation work between the HUB 4 and ASUS?
On my rt-ax86u there is WAN aggregation, however I only have a HUB 3 with 350Mbps so it's not worth it.
RedGooner
  • 1.93K
  • 69
  • 259
Super solver
Message 9 of 11
Re: Hub4
No it does not.
When in Modem Mode, only Port 1 of the 4 ethernets ports work. So i am maxing out the ethernet.
If only VM had put a 2.5Gbps or 10Gbps port on the back of the SH4
But hey i am well happy with the speed.
Andrew-G
  • 8.17K
  • 1.36K
  • 3.7K
Message 10 of 11
Re: Hub4
@Anonymous Does link aggregation work between the HUB 4 and ASUS?
I don't know, but other people have been experimenting using different setups, with some indications claiming success.  You'll need to read the whole of that thread, and it doesn't look a simple task to get it all working.  Even then, you're at risk of a hub firmware update messing things up because you're relying on hub capabilities that aren't supported.  There may be similar posts somewhere in this forum, or more recent knowledge on the matter.
