Message 1 of 7
Hub3
Can i purchase a new hub 3 router and if yes how?
  • 14.87K
  • 2.05K
  • 6.44K
Message 2 of 7
Re: Hub3
No you can't.  They are only available to rent as part of a VM broadband package.
________________________________
Graham
I'm a Very Insightful Person, I'm here to share knowledge, I don't work for Virgin Media, I'm a VM customer. There are no guarantees that my advice will work. Learn more
  • 7.71K
  • 613
  • 1.31K
Message 3 of 7
Re: Hub3
Why do you want one?
Message 4 of 7
Hub 3
My hub 3 is not working. Can i purchase another one
  • 14.87K
  • 2.05K
  • 6.44K
Message 5 of 7
Re: Hub 3
In that case you need to call in to the broadband faults line and report the fault.  The system will test your connection and then make the appropriate arrangements for the faulty hub to be replaced.
The numbers to ring are 150 free from a VM mobile or landline, or 0345 454 1111 from any other phone (chargeable as standard UK landline phone no.).
Graham
  • 7.71K
  • 613
  • 1.31K
Message 6 of 7
Re: Hub 3
All VM equipment is “rented” it cannot be purchased. There is no cost incurred by the user for VM to fix faults.
  • 4.8K
  • 294
  • 547
Message 7 of 7
Re: Hub 3
Hi Shmazdrak
Thanks for you post
Sorry to hear your hub3 is not working
Can you please explain in a bit more detail why its not working
Whats happening
Is this Wifi or Wired you are having issues with
What are the lights currently showing
Have you checked to see if any faults are in the area  virg.in/service​​​​​​​
Gareth_L
