johndm
  • 74
Message 1 of 22
Hub 4 vs BT Smart Hub 2
Just joined the Virgin community after 25 years with BT.
I'm extremely happy with my new fast broadband package (M350), but find the supplied Hub 3 rather inferior to my old BT Smart Hub 2 for wifi.
My main computers are all on ethernet so no issues there, but the wfi signal around the house is much weaker, and our iphones on Virgin mobile are not connecting as well as they did with BT upstairs when using wifi calling
I bought an extender but it was rubbish and made things worse.
Just reading about the new Virgin Hub 4 which seems a massive improvement over the 3 I was suppled with, is there any way I can get the Hub 4
Answers appreciated
DJ_Shadow1966
  • 7.11K
  • 1.36K
  • 2.02K
Message 2 of 22
Re: Hub 4 vs BT Smart Hub 2
Hello
I am afraid that the hub 4 is limited to the 1Gbps service and only in limited areas.
Regards Mike
johndm
  • 74
Message 3 of 22
Thought I read somewhere it was being rolled out to other customers?
spgray
  • 2.39K
  • 139
  • 339
Problem sorter
Message 4 of 22
only in specific cases
My Broadband Ping - spgray
johndm
  • 74
Message 5 of 22
Which are?
spgray
  • 2.39K
  • 139
  • 339
Problem sorter
Message 6 of 22
areas where network is conjested and they move the user over to hub4 to use the ehanced network spec.
and where the area has already been converted to be able to use it.
however, not sure where you read that the hub4 is a massive improvement. most suggest that it is no better and in some cases worse.
if you want a better network put the hub into modem mode and use your own router.
-tony-
  • 16.9K
  • 1.32K
  • 4K
Message 7 of 22
not played with any BT hubs but if you still have your old one it may be possible to use the wifi on that - you would need to log into it and turn off DHCP and set its internal ip address to 192.168.0.xxx - make the xxx a high[ish] number - 99 would do - if thats possible connect it to the hub3 and see what happens - use a lan port on the smart hub would be the correct port i think
all depends if you can change settings in the smart hub
____________________
Tony
johndm
  • 74
Message 8 of 22
Such as?
johndm
  • 74
Message 9 of 22
As we changed to Virgin BT wanted the old hub back, and I don't believe it can be used as a standalone
spgray
  • 2.39K
  • 139
  • 339
Problem sorter
Message 10 of 22
@johndm wrote:
Such as?
such as what?
