GordonJH
Hub 4 problem
I've been successfully running a small family web and email server for several years wired latterly to a hub 3 successfully but since upgrading to a hub 4 at 1Gb a couple of days ago I'm no longer able to make HTTPS or IMAP/SMTP connections from the LAN but can from the WAN. Tracert from a laptop and traceroute from an iMac resolve the to my WAN address.
My son (also a VM customer) told me earlier this evening he was unable to connect from the WAN - he could connect yesterday. After I rebooted the hub he was able to connect again.
Is the connection behaviour to be expected with hub 4 or have I been unlucky enough to have a faulty hub?
Kind regards
Gordon
Tags (1)
  • 19.55K
  • 800
  • 2.07K
Re: Hub 4 problem
NAT Loopback may not be supported by the hub 4 and port forwarding is likely buggy you may have to get your own router and use hub in modem mode.
GordonJH
Re: Hub 4 problem
Thanks for the reply. It's rather unfortunate. It worked on Hub 3. Some of the ports that would need forwarding are reserved which is why we haven't used forwarding.
