Sign in
Sign out
a month ago
Does anyone know if an external hard drive would be compatible with my Hub 4? I want to be able to access the drive via WiFi and would prefer this if possible as it would be cheaper than getting a NAS.
There isn#t a way to connect a hard drive to any of Virgin's residential hubs without use of a NAS device.
Hello
I am afraid that plugging a hard drive into the hub will not work the function isn't enabled on the hub and cannot be enabled.
Regards Mike
