  • 8
Message 1 of 5
Hub 3 - PC auto connecting to 2.4ghz, won't connect to 5ghz - Not fast enough!
Hi!
Just installed the Hub 3 upgrade from Superhub 2. My PC now automatically connects to Hub 3 on the 2.4 band. If I switch the 2.4 band off on the Connect app, the PC won't connect to the internet.
Is there a way to force my PC to stick to the 5ghz connection? If not, I will need to arrange switching to another router.
Thanks/.
  • 4.66K
  • 856
  • 1.24K
Message 2 of 5
Re: Hub 3 - PC auto connecting to 2.4ghz, won't connect to 5ghz - Not fast enough!
Hello
What wireless card is in your PC ?
Regards Mike
  • 3.5K
  • 566
  • 1.38K
Message 3 of 5
Does your PC support 5GHz connections?  If it doesn't have a 5 GHz capable wireless that could explain things.  Many cheaper laptops have 2.4 GHz only adaptors, as are many add on wireless cards for desktops (or in the case of my daughter's one year old Dell desktop, it has wifi built in, but only supports 2.4 GHz).
  • 8
Message 4 of 5
It does have a 5ghz wireless card in the PC so that's not the issue. I have now gone into the settings on the Hub and separated the two bands. Still quite slow though.
  • 89
Dialled in
Message 5 of 5
Have you separated your 2.4ghz and 5ghz channels and also have you tried changing the 5ghz channel as when it is on auto it might be on a channel witch is  incompatible with your WiFi card, suggest starting off on channel 36 and work your way up on channels to see if your pc picks up the 5ghz
My Broadband Ping - 500Mbps
