Mattrm1984
Message 1 of 5
Hub 3 Ethernet Ports Not Working
Hi my ethernet ports have stopped working, all 4. The wifi works fine. I have called Virgin 5 times, each with a 45 minute call wait. I have been lied to, cut off and fobbed off by the staff. I can’t bare to call them anymore. The things they have asked me to do, which don’t work are listed below:
Restart router - Ethernet ports work for 5 minutes then loose connection but the green lights still flash by the ports.
factory reset with hole at rear of router -Ethernet ports work for 5 minutes then loose connection but the green lights still flash by the ports.
factory reset through web page to router -Ethernet ports work for 5 minutes then loose connection but the green lights still flash by the ports.
it got to the point where the Virgin person just couldn’t be bothered to help me anymore and just said there is a known issue in the area and to wait for it to be fixed. I then call up the next day again to see how the issue is going and they have no record of any faults in the area. Liars!
the problem I have is when they ask me to reset it it, it works for 5 mins and then they are like there you go it’s working. Then when I put the phone down it goes again. Then it’s another 45 mins call wait.
any help appreciated, please.
Thank you
Matt
Tags (1)
jb66
  • 12.27K
  • 911
  • 1.78K
Message 2 of 5
Re: Hub 3 Ethernet Ports Not Working
If they work for 5mins thst means one of your ethernet devices are crashing the hub, try reconnecting one at a time.
What do you have wired to the hub?
Mattrm1984
Message 3 of 5
Thanks, I will try that.
I have an Xbox, Apple TV, Samsung tv and a laptop.
it was all working ok or a few years until over a week ago.
Mattrm1984
Message 4 of 5
Well I have tried this and then started trying combinations of them together it appears to be that all the Ethernet ports don’t work unless my MacBook pro is connected and turned on?
xbox on its own cuts out
aple tv on its own cuts out
Samsung tv on its own cuts out
macbook on its own works
macbook with any of the above, they both work
But now..... it’s all not working again so I am at a loss.
Mattrm1984
Message 5 of 5
So just to confirm, nothing is working again.
each items doesn’t work on its own.
it seems the ports just randomly start and stop working.
