Message 1 of 8
How many devices can use virgin media connect hot spit
I was wondering how many devices you can use to connect to virgin media hotspots I am VM mobile and VM broad band ie will mytab connect to a hotspot or is it just phones .. thanks in advance anyone
  • 4.86K
  • 895
  • 1.29K
Message 2 of 8
Re: How many devices can use virgin media connect hot spit
Hello
Yes your tablet should be able to connect to the Virginmedia hotspots as longs as you have install the Virginmedia App on the device.
Regards Mike
Message 3 of 8
Thanks mate appreciate that
  • 5.68K
  • 796
  • 1.62K
Hero
Message 4 of 8
For each VM Broadband account, you use the Connect App on 7 devices.  A phone with a VM SIM in, will use the SIM to sign in - so will not count towards that 7 device limit.  https://www.virginmedia.com/help/devices-for-virgin-media-connect-app
BB 200 - Hub 3, Phone Talk w/ends, Mobile Sim only. Customer since 1993.
Message 5 of 8
Very helpful thanks
Message 6 of 8
To connect to VM hotspot have u got to have a VM mobile  sim ? Thanks again in advance
  • 14.5K
  • 2K
  • 6.35K
Message 7 of 8
No, you can set the Connect app up with just your VM broadband details as explained in the link already posted.
________________________________
Graham
I'm a Very Insightful Person, I'm here to share knowledge, I don't work for Virgin Media, I'm a VM customer. There are no guarantees that my advice will work. Learn more
  • 5.68K
  • 796
  • 1.62K
Hero
Message 8 of 8
Have noticed a bad link in the above link.
If you press "Downloading the Virgin Media Connect app", it does not take you to the Connect App download page - it takes you to the "Virgin TV Control page"🥴
