How long does VM keep IP assignment logs?
I’m really interested to know if VM holds IP log data longer than the mandatory 12 month period. Does anybody have information on this? Possibly somebody who works at VM and can verify it. Also let me know if data is deleted as soon as 365 days is over.
  • 19.58K
  • 1.72K
  • 4.28K
Re: How long does VM keep IP assignment logs?
not sure if virginmedia would supply this data, but i'm sure they are complying with Article 5 (e) of the GDPR, just out of interest are you referring to the IP's you've accessed if that is the case that isn't logged.
