Garfy73
How do i get into advanced settings to adjust settings in the Hub 4
How to change settings on the HUB 4
Talon
  • 43
  • 6
Re: How do i get into advanced settings to adjust settings in the Hub 4
Type 192.168.0.1 in your browser. This will take you to the router admin. The logins are on the bottom of the router. This is for the Hub 3, I'm presuming its similar for Hub 4
