Wigan_Wench
How Does Cover on Outside Box Fit
My outside box cover has blown off. How does it fit back on? Try as I might I can't get it to attach, and I struggle bending.  Very frustrating!
Aaron2
  • 867
  • 98
  • 161
Well-informed
Re: How Does Cover on Outside Box Fit
You don't bend it, it goes on top to bottom, so put it on at a 90 degree angle then once the top is covered you just push it down and it should clip over, it needs a screw to properly keep it in however.
** I work for VirginMedia but all opinions posted here are my own.
