BryanT
Fire charger connection
'I received a Fire from Virgin some months ago-It has stopped charging. My phone charges using the same so it appears to be a fault with the charging point on the device
It hasn't been dropped or damaged in any way!
What do i need to do?
Bryan
  • 19.36K
  • 1.69K
  • 4.23K
Re: Fire charger connection
For faults you should contact Exertis by calling 0128 2858 460 or email virginsupport@exertis.co.uk
Click to learn more about VIP
Use Kudos to say thanks
BryanT
Thank you Paul, that is a great help. Cheers Bryan
