Tom1010
  • 17
External wall box cover missing
the cover for my external wall box has gone missing. It was always loose but I think heavy wind has blown it away or someone had pinched it. Does anyone know how I can get a replacement cover. Will Virgin send one to me?
Tags (2)
  • 7.98K
  • 1.17K
  • 2.18K
Re: External wall box cover missing
Hi Tom1010,
You could try the text messaging service. Just send  a text with a description of Faults  to 07533 051809. Your message will go into a queue and a representative will respond to you as soon as possible. It may take a few days
You can also call  150 from a Virgin landline, or 0345 454 1111, but best to call at 8am to avoid call queues, or late afternoon around tea time.
Dave
Problem Solved? Click to mark as a Helpful Answer or use Kudos to say thanks for a useful post
