Bromz83
External cable cut
Hi all
Having a driveway done and the contractors have cut the cable by accident.
Can Virgin reconnect? Any advice?
spgray
  • 2.39K
  • 139
  • 341
Problem sorter
Re: External cable cut
yes they can, you'll need to call CS and report the issue.
My Broadband Ping - spgray
Bromz83
Cheers. Been trying to for the last 70 mins or so
-tony-
  • 17.66K
  • 1.37K
  • 4.26K
they might want to charge you £99 - depends very much on the agent - they might also want to repull the cable which could stop the drive work or maybe it would be possible to route it a different way
either way you need to speak to the contractor - if they repair it it would be a gel box - these can be permanent but not wise to bury under a drive - if they want a repull i dont think that will happen quickly
____________________
Tony
