Mike4185
Extension
We're getting a home extension and creating a new room for our daughter. Hoping to extend our virgin cabling into new room to get access to all our channels/wi-fi etc
Looked online but couldn't find any obvious area to request Virgin to come out and do work. Anyone done this and can.offer advice?
Andrew-G
  • 10.08K
  • 1.62K
  • 4.54K
Re: Extension
You can try calling in, and booking a "non-fault call out", which will be £25 (and usually well worth it), or if you hold on here the forum staff may be able to book one for you, but can sometimes take a few days for them to get round to replying.
goslow
  • 3.61K
  • 516
  • 1.33K
Community elder
Re: Extension
£25 for a non-fault call out to deal with the wiring to provide another connection in your new extension
https://www.virginmedia.com/shop/the-legal-stuff/priceguides
but presumably you also need some further VM equipment as well for TV, unless you are planning to relocate existing kit to the extension. The wi-fi is provided by the VM hub and you only have one of those per customer so wi-fi coverage will depend on where your existing hub ends up being based relative to the extension and the other rooms in your home.
You can phone in to book the cabling work. Forum staff on here can also arrange that but they don't often visit this 'Tech Chatter' forum.
Roger_Gooner
  • 7.99K
  • 523
  • 1.51K
Re: Extension
I see this as a multiroom, not a non-fault call out .
Hub 3.0, TP-Link Archer C8, TP-Link TL-SG108S 8-port gigabit switch, V6
