Extended power cable for hub 3
Cal_stu
I had to get my hub moved away from my TV, console etc due to interference.
The issue I have  now is the power cable for the hub is too short.
Does anyone know where I can buy a cable that is 2 or 3m long?
1 ACCEPTED SOLUTION
Accepted Solutions
nodrogd
You will not be able to extend the LV lead coming from the power brick, but you can get Fig8 240v volt input leads up to 5 metres in length.
Example
PS. If you do use one of these I would advise to swap the 5A fuse with the 3A one in VMs existing lead.
VM 350BB 2xV6 & Landline. Freeview/Freesat HD, ASDA/Tesco PAYG Mobile. Cable customer since 1993
5 REPLIES 5
What’s wrong with a standard mains cable extension, easy to make yourself or purchase from somewhere like Amazon.
There's nothing wrong with that really.  However,  can I hide the hub power cable being the skirting board much easier than a standard power lead.
You should be able too, I don’t have this problem as my hub is under the stairs.
nodrogd
Example
@Tudor wrote:
<snip>  as my hub is under the stairs.
Ditto, but Harry keeps falling over it ......
