on 26-03-2023 18:22
I bought a USB HDMI capture dongle for my laptop and whilst the video capture is fine, the audio is loud, distorts, clips and drops out completely after a while.
I guess its because the audio is an amplified and not a line level output. I looked on the rear and I spotted a 3.5mm audio jack but that appears to be amplified as well. Just wondered if there was some setting I have missed that alters the audio level from the V6 itself?
Answered! Go to Answer
27-03-2023 09:30 - edited 27-03-2023 09:33
The audio output from the V6 is at a fixed level. I feed this to an amplifier so that I can put sound from concerts/films through my Hi-Fi stack. I feed the monitor out from the stack to an analogue USB capture device into my Windows PC using Audacity software & it works fine. Initially when I set this up the audio kept cutting out even with the levels correct. I traced this to the default microphone audio processing in Windows, & once I turned this off it worked perfectly.
on 26-03-2023 18:43
As far as I know the V6 doesn't have any audio volume controls. If it does I've never found the settings.
I'm a Very Insightful Person, I'm here to share knowledge, I don't work for Virgin Media, I'm a VM customer. There are no guarantees that my advice will work. Please read the FAQs
on 28-03-2023 21:32
I have just done a little test with a 3.5mm stereo jack to 2 phono plugs connected from the 3.5mm jack audio socket on the back of the V6 to the DAB input on my amplifier (as it was spare) and it sounds absolutely fine and a comparable level with the other inputs on my amplifier from the other (line level) sources so it would appear the V6 audio output is a line level output.
So, I guess there is a configuration issue on my Windows PC somewhere with audio capture - I shall have another play with the capture dongle later on in the week and I'll have a good look at the audio settings.
on 28-03-2023 22:34
