Jessie62
Digger cut through cable
My driveway has been block paved. They cut the cable when digging out.
The driveway is complete. Please tell me it won't have to be taken up to mend cable!
japitts
  • 20.68K
  • 2.65K
  • 4.74K
Re: Digger cut through cable
Without seeing the damage and your cabling setup, it's impossible to say....
Can you post some photos? Based on what you've said so far, then needing to get under the paving to complete repairs is certainly a possibility.
LittleMick73
  • 5.39K
  • 547
  • 924
Superstar
Hi if the the cable is under the drive then it will need to be opened up. Regards Micky
