Nickau85
Cut through external cable
Hi, whilst doing some gardening, I’ve accidentally chopped through half of the virgin cable. Some channels work, but most are missing/pixelated. can you please advise how to get this repaired please
SCA1972
  • 5.89K
  • 662
  • 2K
Re: Cut through external cable
Report the issue by calling 150 from a VM landline or 0345 454 1111 from any other phone.  Calling at 8am on a weekday seems to be best.
If you can't get through on the phone then VM are recommending you send a text to 07533 051809 describing the issue and you should get a response, but it may take a day or two at present. This is a text only service, it does not support voice calls.
https://community.virginmedia.com/t5/Digital-life/When-and-how-to-use-our-messaging-service/ba-p/425...
Or you can wait for one of the forum team to get to this thread, which usually also takes a few days.
______________________
Scott
My setup: VM TV box, M350 Fibre broadband with Hub 3 in modem mode connected to a Netgear R7000 router. Telewest/VM user since 2001.
