Oyster
  • 36
  • 7
Message 1 of 7
Casual question about Hub 3
It's no biggie really but just wondered why on the hub 3 box a red light means
everything ok and green lights mean anything from no connection to trying to connect?
There has to be a reason it all deviated away from the standard traffic light system
green - go, amber - caution,  red - danger
jb66
  • 11.97K
  • 880
  • 1.72K
Message 2 of 7
Re: Casual question about Hub 3
It indicates the hub is overheating, is it well ventilated
Graham_A
  • 15.65K
  • 2.19K
  • 6.72K
Message 3 of 7
Red light showing on the Hub3 in router mode means it is overheating and therefore does represent a danger warning.
If in modem mode the light shows as magenta, which some people interpret as red.
________________________________
Graham
I'm a Very Insightful Person, I'm here to share knowledge, I don't work for Virgin Media, I'm a VM customer. There are no guarantees that my advice will work. Learn more
spgray
  • 2.39K
  • 139
  • 338
Problem sorter
Message 4 of 7
not a case of interpretation.
on some hubs it most definitely is red. i've had 2 hub3 and my first one is was solid red, my second one is magenta.
My Broadband Ping - spgray
Oyster
  • 36
  • 7
Message 5 of 7
Oh I forgot to add that, it is in modem only mode
Still the question is more about why the lights are reversed as in whu wasnt a green light used to mean OK everything working?
spgray
  • 2.39K
  • 139
  • 338
Problem sorter
Message 6 of 7
the hub isn't a traffic light so comparing it to that is pointless.
red means a fault - overheating
magenta means the hub is in modem mode (but often the LED is red rather than magenta).
Oyster
  • 36
  • 7
Message 7 of 7
Ok, curt, but succinct, I see your point. The Hub 3 will never be used at traffic junctions to stop cars. Thank you
