Drummo66
Can receive and not send iCloud desktop emails - help! “Client Host Rejected- Access Denied” - ? Help!
Getting Client host rejected Access denied when trying to send mail from iCloud on Desktop -no problem at all using my phone or web browsers. Please can someone suggest what I need to do? Thanks!!!
DJ_Shadow1966
  • 7.23K
  • 1.38K
  • 2.09K
Re: Can receive and not send iCloud desktop emails - help! “Client Host Rejected- Access Denied” - ? Help
Hello
When you say on a desktop what email client are you using ?
Have you checked that the server details are correct ?
The server details can be found here https://support.apple.com/en-us/HT202304
Regards Mike
Drummo66
Hi thanks Nr DJ Shadow -  for getting back to me. What I mean is/ my Apple Mac mini is logged into ICloud. I can do everything.... apart from send mail - Client Host Rejected:Access Denied - I’ve added pix - do I have to manually set this up? It works ok receiving?
I loved your last album
thanks!
DJ_Shadow1966
  • 7.23K
  • 1.38K
  • 2.09K
Hello
Been looking around to find you a fix for this, and after much searching the error you are getting will need to be looked at by Apple Support as it is due to a problem on either the MAC or on Apples server.
Regards Mike
