Da_WorstNetwork
Can I fibre Cables installed outside my house if I pay?
I contacted Openreach like two weeks to see if I can pay for fibre cables to be installed in my area. They said I would need to do a ‘community survey’ something like that in order to get the fibre cables installed.
There is a new build at near me, so they would have fibre internet available but would of it better if they installed fibre cables at the same time?
So I was wondering, what if I pay Virgin Media to install fibre cables? I get download speeds at 5-11Mbps and upload at 1Mbps and it’s a complete joke, so would it be possible to pay for installation of fibre cables to be installed?
Andrew-G
  • 7K
  • 1.22K
  • 3.06K
Re: Can I fibre Cables installed outside my house if I pay?
If there's an existing VM network just round the corner then the company is open to customers paying for connections, but as rough indication distances over about 150 metres won't be technically possible without additional amplification (costing thousands or pounds) and if the cabling needs a new run under pavement you're looking at costs in the region of £150 per metre from the existing network.  All that can easily mount up to some very serious money.
In terms of any Openreach options associated with the new development, you'd be best off asking in the customer forum for BT, or a site like Thinkbroadband.
  • 6.49K
  • 1.01K
  • 1.61K
Hi Da_WorstNetwork,
Have you used the VM postcode checker to see if VM is already available at your property?
Dave
Have I helped? Click to mark as a Helpful Answer or use Kudos to say thanks
Da_WorstNetwork
Yes, but not available in my area. There is a new build behind me. So I wondering if I’m able to get it installed if I pay for it. I don’t think I’ll be getting fibre any time soon.
nodrogd
  • 16.82K
  • 1.97K
  • 4.08K
If the road is private, block paved or has no pavement VM usually won't touch it with a barge pole. The infrastructure in the adjacent roads will only be capable of serving those roads (number of tap points in cabinets & the maximum range of the amplifier). Adding on new roads now is usually full fibre if it was not in the original build plan, but this is dependent on there being a large demand in the road being serviced.
VM BB TV Landline PAYG mobile. Freeview/Freesat HD, Tesco Mobile. Customer since 1993
Andrew-G
  • 7K
  • 1.22K
  • 3.06K
Well if the VM postcode checker shows you can't get VM services (coax or fibre doesn't matter), then you might want to see if your area is on Openreach's plan.  Whilst lots of places are still not covered, the plan to 2025 looks like about 80% of the population will have FTTP options over the next few years, although I appreciate that's a long time to wait.
