DJV1
Cable
Virgin Road gang are here laying cable to the enclosures on the pavement. Good timing as I currently have my driveway dug up. Thinking ahead can I lay a cable underneath the subase to the front of my house from the front of my drive ready for them? If so what cable should I use?
Thanks!
Christy_D
  • 1.65K
  • 231
  • 257
Re: Cable
Hi there
We wouldn't advise that you lay the actual cable as we would need to lay the Fibre/Coax. I assume if they are laying the cable then it will be an FTTP area.
However customers do lay the conduit themselves and we can then feed the coax or FTTP ducting through this.
Christy
DJV1
Re: Cable
Thanks! I'll lay some conduit over the weekend...appreciate you're help.
spgray
  • 2.39K
  • 139
  • 341
Problem sorter
Re: Cable
unless your conduit lines up exectly with the T-point they will install on the pavement then you would be wasting your time.
the cable can only run from the T-point to your house.
My Broadband Ping - spgray
