Bilbo166
Cable
Want to move my hub, where can I get a longer  isolate cable push fit 10 meters
DJ_Shadow1966
  • 7.12K
  • 1.36K
  • 2.02K
Re: Cable
Hello
Only an engineer can modify the cable as extending the cable more than a couple of meters will affect the signal level, as well as being against the T&C as self modifying the cable can cause noise ingress and affect everybody who connects to the same cabinet as yourself, there will be a charge of £99 to do the move.
Regards Mike
