Crazy_Legs_15
  • 5
Message 1 of 9
Cable spec - moving router and TiVo box closer to internal box
Hi, when we had virgin installed our router and TiVo box were situated on the opposite side of the room to where the internal box is so a long wire/cable pinned to the wall was required.
We have since moved the router and TiVo box to the corner of the room where the internal box is located so we now have a lot of excess wire/cable.
I’ve spoken to virgin and they’ve said I can either get a technician to come round to change the wire (at a cost of around £90), tie up the excess cable (this is what I’m currently doing), or buy a replacement cable myself. Would anyone know what spec the cable is that I need to purchase and any recommendations on the best place to get it?
Tags (3)
DJ_Shadow1966
  • 6.86K
  • 1.31K
  • 1.9K
Message 2 of 9
Re: Cable spec - moving router and TiVo box closer to internal box
Hello
I am afraid that the information regarding buying your own cable is wrong, you can only use cable that is supplied by VM to reduce the distance as per the T&C's, how long of a cable are you looking for ?
Regards Mike
Crazy_Legs_15
  • 5
Message 3 of 9
Hi Mike, it only needs to be about 1m long (probably shorter), do you know if there is there a way I can get it delivered from VM?
nodrogd
  • 16.47K
  • 1.92K
  • 3.94K
Message 4 of 9
You may be able to get the cables from a QuickStart kit sent out, but my worry is how much cable has been removed as anything in excess of 5 metres could require a signal adjustment.
Virgin BB TV Landline. Freeview/Freesat HD, Virgin Mobile, Tesco Mobile. Cable customer since 1993
Crazy_Legs_15
  • 5
Message 5 of 9
Thanks nodrogd, it will probably be more than 5m shorter as it was pinned along 3.5m wall and around a doorframe previously
Roger_Gooner
  • 6.54K
  • 473
  • 1.14K
Legend
Message 6 of 9
One possibility is to reinstate the hub, at least you'll reduce the excess cabling by half.
Hub 3.0, TP-Link Archer C8, TP-Link TL-SG1008D 8-port gigabit switch, V6
Crazy_Legs_15
  • 5
Message 7 of 9
Hi Roger_Gooner, how would I go about achieving that?
Roger_Gooner
  • 6.54K
  • 473
  • 1.14K
Legend
Message 8 of 9
I meant putting it back in its original place unless there's now a good reason to keep it where it is.
Crazy_Legs_15
  • 5
Message 9 of 9
That's not an option, where the TV and router used to be is now a play area/toy storage, they were moved to keep the kit safe from small hands!
