  • 13
Cable repair
My wife has cut through the canle from the street to the box on the house. Is there any way of joining it back together. Have to wait over a week for an engineer.
  • 30.25K
  • 1.51K
  • 5.24K
Re: Cable repair
no you will need to wait for an engineer to replace or repair the cable
  • 29
Re: Cable repair
could they use an ordinary electrical cable connector to join the copper core and tape it up till engineer arrives, also does a severed cable introduce noise on circuit
