Ersan
Cable connection to router
I have one cable coming into my property which then was split into another room as we have TV in two rooms. we no longer use these TVs so I disconnected the cables. at the moment the outside cable comes inside and connect to a tris1002AEN and then the cable plugs into the adaptor and then into theu router.is this correct. Also I have a 6 DB filter that was come the other cable I think is this needed
japitts
  • 12.24K
  • 1.7K
  • 2.64K
Re: Cable connection to router
Not actually sure what you're asking... do you have a question?
Roger_Gooner
  • 6.75K
  • 490
  • 1.19K
Legend
What speeds are you getting and do you have any problem? If you do have a problem VM should get a tech round to replace the splitter with a barrel connector and check signal levels with and without the 6 dB attenuator.
Hub 3.0, TP-Link Archer C8, TP-Link TL-SG108S 8-port gigabit switch, V6
