Forestchick619
  • 6
Message 1 of 12
Brown box issue why does my rooftop aerial run through it
I've recently been having problems with my rooftop aerial. I'm not a virgin media tv customer only virgin broadband and these issues only started when the wifi cables where installed. I have a rooftop aerial as stated before to use freeview that is built into my tv. Connection issues seem to be coming from the connection inside the brown box where the aerial cable is coming from into the property but because its a virgin media brown box i was told only virgin media can open it up and have look as the connection is there's but why then would a freeview aerial even be connected through that port? And could it be when wifi was installed was my aerial connection disturbed in some way and would this mean that virgin have to come out and take a look at it or would it be someone and can they access it with it being virgin media 'property' as such i'm so confused and have no idea where to go or what to do i just want my freeview tv back my areial to work as it did before wifi was installed in that point
Anonymous
Not applicable
Message 2 of 12
Re: Brown box issue why does my rooftop aerial run through it
vm won't of used the aerial cable and VM wouldn't;t be able to fix it. what do you mean the cable goes into the brown box. can you get some photos. remove the cover and get some pictures
Forestchick619
  • 6
Message 3 of 12
I couldn't get the box off it seems to be either tied or jammed but i've managed to get some photos and explained it the best way i can... I'm trying to upload them but its saying the file size exceeds the requested limit
Forestchick619
  • 6
Message 4 of 12
Forestchick619
  • 6
Message 5 of 12
 inside of brown box... Looks like the cable running from the ground is connected together by this thing whatever it is which in turn runs through to the property and is entwined and connected to the rooftop aerial and the cabke running to the bedroom
Roger_Gooner
  • 6.53K
  • 472
  • 1.14K
Legend
Message 6 of 12
It seems to me that the VM cable loops down (the leftmost one). Where does it lead to?
Hub 3.0, TP-Link Archer C8, TP-Link TL-SG1008D 8-port gigabit switch, V6
Forestchick619
  • 6
Message 7 of 12
Its runs from the ground then there is this connector thing then a cabke running into the property
Roger_Gooner
  • 6.53K
  • 472
  • 1.14K
Legend
Message 8 of 12
I'm looking at the cable that comes out of the tube, is connected to another cable which runs downwards. Where does this cable lead to?
Forestchick619
  • 6
Message 9 of 12
The thick black cable with the silver connector? If so that is the wifi cable which goes to my bedroom
  • 8.13K
  • 649
  • 1.42K
Message 10 of 12
If so that is the wifi cable which goes to my bedroom” there is no such thing as a WiFi cable. I think you mean it’s the VM broadband cable. Which cable/s go to your TV aerial?
