Broadband hub3
Is the hub3 duel band if yes how do you change it to 2.4GHz
  • 14.45K
  • 1.98K
  • 6.33K
Re: Broadband hub3
Yes it is.  The WiFi band's can be disabled via the Hub's user interface.
________________________________
Graham
I'm a Very Insightful Person, I'm here to share knowledge, I don't work for Virgin Media, I'm a VM customer. There are no guarantees that my advice will work. Learn more
  • 7.53K
  • 592
  • 1.28K
Legend
Re: Broadband hub3
As shipped the Hub3 uses one SSID for both the 2.4 & 5 GHz bands. A large number of people have fixed problems by separating the bands to use different SSID names for each band, like xxx_2 and xxx_5. It’s an easy change in the hubs settings.
