bungle2020
  • 9
Message 1 of 10
Another cut cable!
Hi. I'm another one who has ended up cutting our Virgin cable. I was trimming the bush near our front door and accidentally sliced through the phone cable under the door. The phone is off, but the internet is still on.
-tony-
  • 16.53K
  • 1.31K
  • 3.9K
Message 2 of 10
Re: Another cut cable!
wait for VM to get to the thread - they will sort a tech - there are usually 4 wires in the phone cable - all colour coded if there is enough wire you could join them as a temp repair - some insulating tape to keep them waterproof until the tech gets there to do a permanent job
____________________
Tony
bungle2020
  • 9
Message 3 of 10
Thanks. I did consider trying to join the cables somehow, as I’m a technically minded person, but there isn’t enough slack.
  • 8.13K
  • 649
  • 1.42K
Message 4 of 10
Just jump the gap with some spare cable.
bungle2020
  • 9
Message 5 of 10
I could try that, if I can find something suitable.
bungle2020
  • 9
Message 6 of 10
We managed to book an engineer to fix it. Apparently they're going to charge us £99 for it.
-tony-
  • 16.53K
  • 1.31K
  • 3.9K
Message 7 of 10
it should be free - will flag it and see what VM say
Tony
bungle2020
  • 9
Message 8 of 10
Thanks.
Chris_W1
  • 4.05K
  • 181
  • 252
Message 9 of 10
HI bungle2020, thanks for contacting us, this would not be charged at £99.00 and should be free. I will send you a private message to look in to this further for you ^Chris
bungle2020
  • 9
Message 10 of 10
Thanks.
