RobB68
Sky cinema problem
Sky cinema app asks for update, but App Store says app is unavailable in region or country
Tags (2)
Graham_A
  • 16.16K
  • 2.26K
  • 6.9K
Re: Sky cinema problem
That will be because Sky have discontinued the cinema app.
If you are a subscriber to Sky Cinema through Virgin Media all the live Sky Cinema channels are available via VM TV GO, plus a limited selection of on demand movies.
https://community.virginmedia.com/t5/TV-on-the-go/Sky-Cinema-is-on-TV-Go/td-p/4325332/jump-to/first-...
________________________________
Graham
I'm a Very Insightful Person, I'm here to share knowledge, I don't work for Virgin Media, I'm a VM customer. There are no guarantees that my advice will work. Learn more
RobB68
Thanks, I found all the films
