morningfield
Just joined
parental control will not turn off on home broadband despite switching off at my virgin media
i have followed inatructions
my virgin media
my apps
web safe
child safe - this shows "off" but isnt
Tags (1)
用心棒
  • 5.93K
  • 666
  • 2.06K
Re: parental control will not turn off on home broadband despite switching off at my virgin media
What happens when you try to visit nordvpn.com; in its default configuration Web Safe will block access if it is still on?
Have I helped? Click Mark as Helpful Answer or use Kudos to say thanks
DJ_Shadow1966
  • 7.1K
  • 1.36K
  • 2.01K
Hello
Have you turned off the hub for 30 secs and then back on ?
The device you are  testing this on can you also turn this off then back on.
Regards Mike
