urbanaspect
  • 11
Websafe does not work even though appears switched on
Reviving this thread as it is a year on and still Web Safe does not work. The issue was previously slightly complicated as I was using a laptop that routed traffic through a filter but I have since changed jobs and checked against several devices and I can categorically say Web Safe is not working.
Please help as I am desperate to protect my kids from internet harm. When I started this thread I was being pre-emptive, now they are at the stage they need the features of Web Safe which despite appearing to be 'On' and in use filters absolutely nothing out (whether blocked based on category or specifically blocked sites - neither works).
urbanaspect
  • 11
Re: Websafe does not work even though appears switched on
Reviving thread as still no resolution. I have reset my router to factory settings, Web Safe is on, I have added some sites to be blocked, yet still I can access categories and sites that should be filtered out. Timer settings: Never turn off.
Your DNS Server: 62.252.69.14
Owner of this server: Virgin Media
Status of this server: Everything is fine
I am increasingly concerned about the content available to my children online as they are getting older and using the internet for greater periods.
用心棒
  • 7.37K
  • 813
  • 2.48K
In Windows, open a Command Shell and enter the following command:
netsh interface ipv4 show dnsservers
 Post the resulting output here.
Have I helped? Click Mark as Helpful Answer or use Kudos to say thanks
urbanaspect
  • 11
Configuration for interface "Ethernet"
DNS servers configured through DHCP: 150.206.1.2
Register with which suffix: Primary only
Configuration for interface "NordLynx"
Statically Configured DNS Servers: None
Configuration for interface "Ethernet 3"
DNS servers configured through DHCP: None
Configuration for interface "Local Area Connection* 1"
Configuration for interface "Local Area Connection* 2"
Configuration for interface "Wi-Fi"
DNS servers configured through DHCP: 194.168.4.100
194.168.8.100
Configuration for interface "Bluetooth Network Connection"
Configuration for interface "Loopback Pseudo-Interface 1"
John_GS
  • 13.42K
  • 682
  • 1.24K
Hi urbanaspect
Thanks for posting. Sorry it's not working. I'll PM you now to assist further
Best,
John_GS
  • 18.98K
  • 782
  • 1.99K
unplug the Ethernet reboot and test by WiFi
